Topics68,261
Posts684,875
Members10,938
Most Online14,755 May 5th, 2019
74 registered members (Alex Lynch),
1,050
guests, and 816
spiders. |
Key:
Admin,
Global Mod,
Mod
now what?
#354338
01/22/11 9:23 pm
dale karger
Posts: 163 |
events in my life have caused me to drop my bonne project for a long time. but now i am able to start back on it a little at a time. i have the engine ( 76 OIF 750 ) down on the work bench and am working on splitting the case. I removed the the contact cover and also removed the contact plate. the bolt holding the advance unit was pretty rusty. i heated with a torch and soaked it with penetrating oil several times. and as with as much finesse as i could muster proceeded to snap the head of it off. I am guessing that the rest of the screw is in the camshaft. i am going to replace both of them so i dont "think" i have to worry about it too much. but how do you get the lobed cam off of the shaft so i can get the advance off? gear puller?
76 T140V 79 Honda CB 650 79 Yamaha 175 Enduro 68 Chevy Impala Convert - - - - - - - - - - - - - - - - -
Re: now what?
[Re: dale karger]
#354340
01/22/11 9:31 pm
40 Below!
Posts: 278 |
Wrap a piece of leather around the cam and grip it with vice grips. GENTLY work it up and down and side to side. The taper will let loose and you can remove the cam. You can then proceed with the take down.
"Growing old is obligatory - growing up is optional" 2015 HD Geezer Glide 85 Sportster Rocket Ship 69 Sportster resto project 66 TR6SR(750 tracker) ?? TR25 tracker 67 441 resto project
Re: now what?
[Re: dale karger]
#354586
01/24/11 10:44 am
dave jones
Posts: 3,887 |
The tool for removing this part is just a bolt with the threads removed at the end. There is a thread in the actual auto advance (probably UNF on your bike). When you screw the bolt in it presses on the camshaft and the advance pops off. In your case you would have to vary the unthreaded portion to allow for the piece of broken fixing bolt in the camshaft.
Re: now what?
[Re: dale karger]
#355403
01/28/11 8:57 pm
dale karger
Posts: 163 |
it broke off even with the end of the advance. so i spent the better part of the day carefully drilling ( and trying an E-Z out to no avail ) but have it down almost 1/2 inch deep and i can see the threads on the internal part of the advance. how much further do i have to drill to get to the end of where the advance meets the cam??
Re: now what?
[Re: dale karger]
#355430
01/29/11 12:30 am
40 Below!
Posts: 278 |
Sounds like almost an inch you have worried off the end of the bolt. The thread in cam itself is 5/16. Thread a 5/16 bolt into as far you can and it may bottom out on the stump you have left in there. It may break loose the taper. If not see the post I put on earlier, that does work.
Re: now what?
[Re: dale karger]
#355439
01/29/11 2:55 am
JubeePrince
Born To Run
Born To Run
Posts: 7,564 |
If you can thread a 5/16" (UNF) bolt onto the AAU, a *light* but firm tap on the bolt head N - S - E - W. Unless the thing has been sitting underwater, it should fall off the camshaft taper into your hand.
'77 T140J "Vintage Bike". What's in your garage?
Re: now what?
[Re: 40 Below!]
#355596
01/30/11 7:38 am
dale karger
Posts: 163 |
Sounds like almost an inch you have worried off the end of the bolt. The thread in cam itself is 5/16. Thread a 5/16 bolt into as far you can and it may bottom out on the stump you have left in there. It may break loose the taper. If not see the post I put on earlier, that does work. i saw that and did try that. first i used rubber from a an inner tube...then i did heat the shaft and use leather. its not budging at all. hence why i posted again. i hate to strong arm something for fear of doing more damage than i can fix.
Re: now what?
[Re: dale karger]
#355617
01/30/11 12:08 pm
JubeePrince
Born To Run
Born To Run
Posts: 7,564 |
Dale,
Try the 'tapping' method. The shock of the tool hitting the bolt is what will release it from the taper....
Steve P
