Support Your #1 Forum
Buy BritBike's staff a coffeeStill here since 1996.. Click here to buy BritBike staff a coffee.
30 registered members (Alan_nc), 293 guests, and 262 spiders.
Fumi, brennan devine, sivaraj, LarryL, chickin
10613 Registered Users
franko 121
koan58 81
Mori55 72
reverb 64
NickL 60
831,727 mail-order LSR
Topics67,840
Posts672,060
Members10,613
Lower fork bolt size #341869
11/07/10 1:32 pm
11/07/10 1:32 pm
rmak Offline OP
rmak  Offline OP
Dang, I just repaired one fork and then the other started to leak. This is on my 65 TR6. It's leaking from the bottom of the fork. I wish I would have cleaned and sealed the parts on both forks before I put the bike together.
I borrowed a small whitworth socket to take the first fork apart and clean. Now I forgot the socket size. I tried all of my standard and metric sockets and nothing is close. I want to buy one of these little sockets so I have it on hand. Does anyone know the size I need? The socket I need fits the small bolt that is exposed right on the bottom of the lower fork slider after you remove the wheel. I have a whitworth socket set, but the bolt is smaller than my smallest one.
Thanks.
Re: Lower fork bolt size [Re: rmak] #341894
11/07/10 3:44 pm
11/07/10 3:44 pm
Stuart Offline
Stuart  Offline
Just so we're clear:-
. Whitworth is an actual threadform with particular hex. AF's corresponding to particular thread nominal diameters.
. The fork threads will almost certainly be Cycle (aka CEI and BSC); Cycle nuts 'n' bolts are also referred to by thread nominal diameter rather than hex. AF's, and use the same hex. AF's as Whitworth, but Cycle usually uses one size smaller hex. AF than the same diameter Whitworth (e.g. 5/16" Cycle - 0.52"AF, 5/16" Whitworth = 0.6"AF). A point to bear in mind if sockets are actually marked "Whitworth" (or "BSW").
Then, just to be even more confusing, iirc that bolt is 'small hex.' - i.e. although its thread nominal diameter is 5/16" Cycle, the hex AF is what'd normally be found on a 1/4" Cycle - 0.445"AF. Or, if you've tried that, it could be the next one down - 0.324"AF.
Confused? Jolly good. grin
Fwiw, the first socket set I ever bought, that still helps me out occasionally, instead of having markings for Olde Englishe sizes, has a few sockets marked xx/32"AF; however, 'til I started fiddling with Olde Englishe clunkers, I never knew what they were for. So when you go searching for a socket to own, bear in mind 11/32" for 0.324", 15/32" for 0.445" or 17/32" for 0.52".
Re: Lower fork bolt size [Re: Stuart] #341952
11/07/10 7:43 pm
11/07/10 7:43 pm
rmak Offline OP
rmak  Offline OP
This is why I love this forum....OK, regardless of what you want to call them, does anyone know the socket size I need to get that bolt out of the bottom of the lower fork leg on a dry frame?
Re: Lower fork bolt size [Re: rmak] #342043
11/08/10 2:30 am
11/08/10 2:30 am
I don't know which size yours is but I just looked in my tool box and found one socket that is 5/16 and another that is 17/32 both are ground down around the outside to fit in that too small hole.
Re: Lower fork bolt size [Re: rmak] #342052
11/08/10 3:22 am
11/08/10 3:22 am
Oregon
M-Runner Offline
M-Runner  Offline
Oregon
If your small restrictor bolt hex is the same stock size as a 66' you can use a DEEP 8mm 12 point socket, the one I use is a Snap-On, it's fairly thin and fits into the cavity of those lower bolts on my bikes (66,67,68,69) perfectly.
Tom
Re: Lower fork bolt size [Re: rmak] #342222
11/08/10 11:44 pm
11/08/10 11:44 pm
Nor Cal near Sutters mill.
Roadwarrior Offline
Roadwarrior  Offline
I use an 8mm 12pt also, that is skinned down on the outside due to the tight clearance. I use a small o-ring under the head that is available at any hardware store. I kept loosing the socket also until I put it in it's own marked plastic bag.
The shrieking of nothing is killing
Re: Lower fork bolt size [Re: Roadwarrior] #342226
11/09/10 12:03 am
11/09/10 12:03 am
Stuart Offline
Stuart  Offline
Originally Posted by HawaiianTiger
5/16
Originally Posted by M-Runner
8mm
Originally Posted by Roadwarrior
8mm
... suggest that the nominal AF should be 0.324" (normally 2BA and 3/16" Cycle/BSF). 5/16"AF and 8mmAF often can be too small (0.3125" and 0.315" respectively), but old bolts could be slightly smaller now and Snap-On scokets, particularly, grip the flats rather than the corners, so could have enough clearance.
Bill: I suspect 17/32"AF might've been 'ground down' to fit restricted access on something bigger? wink
