bsalloyd
bsalloyd
Santa Fe, Texas
Amal 276 float height
#311209 05/03/10 3:25 am
kngkong Offline OP
Having a great time breaking in the new engine by taking the long way to work on the coastal roads. The Sppedtwin is running great except that it doesn't like to idle once its hot. Starting the bike usually takes a bunch of kicks, I go easy on the tickle cause it seems to flood too easily, but the bike will idle nicely once it starts cold. I usually ride for about a half hour and when I arrive the bike will usually shut itself down as I coast to a stop. Restarting the bike at this point is pretty hard and usually needs a good rest.
If I set the idle high it will run all day.
Im thinking this must be a carb issue. It is a new carb and I didnt do a clean out before installing. Does the pilot jet on the 276 use the same #78 drill to clean like on the 930's or is it something else. I know Ive read of people just using the wire from twisty ties.
Also, not having much luck searching for info regarding AMAL 276 float height setting. Can anyone run me through setting my float height or point me towards some documentation. I dont believe the owners manuals explains it for the 276, it does for the later monoblock.
Ive checked for air leaks and havent found any yet.
1951 5T Speedtwin
Re: Amal 276 float height
kngkong #311213 05/03/10 3:44 am
Mr Kong -
Sure. No prob.
• The pilot jet you seek is under the small dome nut on the underside of the carb. Use a 1/8W wrench to remove the dome nut. Then a standard straight blade screwdriver to remove the jet itself. Do the usual blow though, look through. You should see straight through. The most common issue is a single drop of water blocking the jet.
Note the chamfered end. The pilot jet will leak and go rich if not seated tightly into the body. Run it in to about 1 ft-lb of torque, turn the fuel tap ON and gas should run out freely, then replace the nut.
Pilot jets are numbered and available in various sizes. #25 and #30 are the most popular, I believe.
• The float level on all Monoblocs is at the "pip" in the middle of the round cover, right smack in the middle of the word "AMAL". With the pilot jet dome nut removed, place a 6" piece of clear 1/8" ID tubing over the pilot, and make a U-turn so that the open end lies on the float bowl cover. Turn ON the fuel and the liquid level should rise to the "pip".
:bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
RF Whatley #311218 05/03/10 4:10 am
kngkong Offline OP
Most excellent, thanks a lot RF! Been searching for days for that info.
Ill give all that a try.
Anything else you can think of regarding running worse when warm (ie, half hour ride on a nice cool day)?
1951 5T Speedtwin
kngkong #311220 05/03/10 4:21 am
Isn't the 276 carb the pre-Monobloc with the separate float chamber?
Gordo in Comox #311223 05/03/10 4:34 am
kngkong Offline OP
yeah, its the pre-Monobloc. Were those instructions for the Monobloc? I didnt realise.
1951 5T Speedtwin
kngkong #311426 05/03/10 10:19 pm
kngkong Offline OP
can anyone help with the same info for pre-Monobloc?
1951 5T Speedtwin
kngkong #311435 05/03/10 11:24 pm
AMAL never published a fuel level for the Pre-Monobloc carburetter and there are no easily identifiable marks to judge it against. The weight of the float and the position of the groove in the needle were calculated to give the correct fuel level which was not expected to require adjustment. Three lengths of Mixing Chamber Union Nut were used to allow for the angle of downdraught on the carburetter and keep the fuel at the correct level.
There is a drilled and tapped hole in the float chamber boss that can provide an attachment for a tube to show the existing fuel level.
As the Speed Twin uses a carburetter with a 7 degree downdraught you have the option of adjusting the position of the float chamber relative to the carburetter. Moving it rearwards will raise the fuel level slightly.
The other adjustable option is the the thickness of the fibre washer above the float mounting boss.
The pilot jet is a drilling in the front edge of the jet block and is easy to get at and clean once the jet block is removed.
Of course, not idling and being hard to start when hot are also classic symptoms of a weakness in the ignition system. Have you checked the condition of the spark on both cylinders when the engine is hot?
Phil Beresford #311436 05/03/10 11:34 pm
kngkong Offline OP
Thanks for the answers Phil. Ive been wondering what Ive doing wrong that I couldnt find much carb maintenance info on the 276. I noticed this morning when starting cold I got her to idle but I think it may be firing intermittently on only one cylinder at idle. If I raise the throttle it is definately firing on both. A little messing with the cables and it seemed to affect the mis-firing cylinder at idle.
I think Ill give the jet a clean out to make sure but I dont think its the culprit. Ill make sure the Im getting good connection to the mag on the offending cable.
To check spark when hot are you suggesting just taking out the plug and laying it on the cylinder to check for spark?
Though, I would think if I was having ignition issues with heat it would affect above idle as well? It doesnt feel like an ignition problem as it just plain shuts off as I get back down to idle after a ride. Hmmmmmm smile
1951 5T Speedtwin
kngkong #311438 05/03/10 11:56 pm
kngkong Offline OP
also...
What is the cause of weak ignition when hot?
1951 5T Speedtwin
kngkong #311487 05/04/10 6:46 am
Mr. Kong,
The most common cause of weak ignition when hot on these bikes is a bad condenser, the second being a break in the windings of the mag's armature. For a diagnosis, try attaching a common automotive condenser to the kill button terminal to see if the spark intensity returns to normal. This may be your idle problem when hot but it seems to me unlikely. It probably wouldn't run well at any speed.
HawaiianTiger #311648 05/05/10 2:30 am
kngkong Offline OP
Originally Posted by HawaiianTiger
Mr. Kong,
Thanks HawaiianTiger!
Sounds like a good test. Ill try it but like you mention it might not be the problem. Ive started a new thread here regarding why Im only running on one cylinder as its not really related to float height.
And where do you attach the condensor? On the end of the mag? Just inline?
Thanks for the tip!
john
1951 5T Speedtwin
