Tinker Tom
Tinker Tom
Texas USA
turflok, Carl Courson, Roddy Walsh, Mark Creighton, Alex Lynch
10778 Registered Users
franko 129
NickL 62
DavidP 56
MarcB 52
950,088 mail-order LSR
Topics67,517
Posts675,828
Members10,778
67 registered members (Adam M.), 495 guests, and 815 spiders.
lucas 6v/60watt E3LM-MO dynamo #19660 01/14/07 11:20 pm
Dick1969 Offline OP
Is there someone that can help me with a diagram, drawing or picture of the wiring of the Lucas 6v/60watt E3LM-MO dynamo.
If it maters at all witch coil side has to be connected to F and to earth. And witch brush needs to be connected to earth and to C.
thanks
1954 BSA B31 plunger
1989 GL1500 Aspengate
Re: lucas 6v/60watt E3LM-MO dynamo #19661 01/15/07 1:25 am
GOLD S-TARvin R.I.P. Offline
Two really good sites for anyone using a dynamo.
"where's that dynamo coming from?"
Check em out:
credit to pinman
lucas manual
2c
GOLD S-TARvin
OVBSAOC # 1625
1960 DBD34 Gold Star
1956 DB34 Gold Star
1969 Bonneville
several basket case Triumphs
Re: lucas 6v/60watt E3LM-MO dynamo #19662 01/15/07 1:36 am
John Healy Offline
If my memory serves me:
The two field wires crossed as they emerged from the field. One has a yellow band around it (it will be placed through the right hand hole in the end plate - the other doesn't and is fed through the left hand hole in the end plate - as viewed fron the brusg end with the armature at the top.
Looking down at the generator from the brush end, Armature toward the top, the filed wire with the yellow band emerges through the hole in the end housing on the right side and looped over to ground. It was joined at the same ground point by the left brush wire. The right brush wire went to the connector marked "D" and the field wire emerging from the left hole in the end housing went to the "F" connector.
Now this is the wiring for a positive ground Triumph E3L, but I think it is the same for the BSA.
Re: lucas 6v/60watt E3LM-MO dynamo #19663 01/15/07 1:59 am
RF Whatley Offline
John, all you said is correct. Would only like to add, I find it easier to remember that field wiring is dependent on the desired direction of rotation. So it would depend on the model of bike as to which direction the dynamo is turned in service. Using this you can fit any dynamo to any bike (if they mechanically fit) and wire to suit.
Then you can bench test by connecting D & F to neg 6V, and the body to pos 6V and see if the rotation is correct.
That's much easier on the old grey cells, don't you think?
:bigt:
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: lucas 6v/60watt E3LM-MO dynamo #19664 01/23/07 9:50 pm
ca7a Offline
Matters not which field wire goes to D or F as long as you "flash"
(polarize) the field after connecting them. THEN you need to mark one of them for the next time you disconnect (or reflash if you didn't).
As for "C ", I guess you meant D.
