T120C
T120C
BradM, Andrew C., muzza123, Siwy, Troy Walls
11012 Registered Users
franko 134
koan58 69
DavidP 50
1,148,432 mail-order LSR
Topics68,913
Posts690,774
Members11,012
58 registered members (Al Eckstadt), 1,089 guests, and 923 spiders.
T140V R. brake #143129 06/18/08 2:09 am
Mike Baker Offline OP
Who's the sadist that designed the rear master cylinder setup for these?
Ok I feel better.
Is there any time proven trick to re-attaching the return spring? Seems that about a dozen things need to align properly to make this happen. Or am I overlooking something?
Thanks, Mike
Re: T140V R. brake #143130 06/18/08 3:39 am
JubeePrince Offline
Born To Run
Born To Run
You mean other than removing the left-hand silencer, rear wheel, final drive chain and the skin from four knuckles!? :p
Seriously, Mike, what you need is:
1) good stiff piece of 1/8" or 3/16" round stock and bend it up like the photo.....(hint: a coat hanger could work if you use it in loop fashion)
[img]http://i182.photobucket.com/albums/x250/JubeePrince/tool.jpg?t=1213760196[/img]
2) If you don't have strong fingers use a pair of Vise Grips to grab the handle end of the hook you fashioned....will save some skin on your fingers.....
3) I use a screwdriver in the other hand to 'persuade' the end of the spring over the edge of the trunnion lever...
HTH,
Re: T140V R. brake #143131 06/18/08 2:54 pm
Stuart Offline
[b]
You mean other than removing the left-hand silencer, rear wheel, final drive chain and the skin from four knuckles!? [/b]
Actually, if you remove the engine from the frame, you can raise the rear brake lever high enough that the inner lever just drops into the spring loop. Then the rear brake lever can be pushed down by hand 'til the trunnion engages on the master cylinder threaded rod, followed by the forward securing nut. Then just replace the engine in the frame.
wink
Re: T140V R. brake #143132 06/18/08 5:26 pm
JubeePrince Offline
Born To Run
Born To Run
laughing Brilliant!
Re: T140V R. brake #143133 06/18/08 10:26 pm
Thanks for the replies.
Hmmm- maybe not the engine, but how about the footpeg?
I've decided I like drum brakes.
Mike
Re: T140V R. brake #143134 06/19/08 2:41 am
trumpetloon Offline
Mike... visit Harbor Freight and look for a set of auto body pull rods... they look like Jubee's photo but are made from spring steel and have "T" handles made on. Work slick as owl poop. If no Harbor Freight local to you see an auto body repair parts house... most fair size communities have at least one. Or even an automotive paint store could supply a set. Mine came from Snap-On but they cost dearly. Happy trails... and long live disc brakes! :p
1974 TR5T
Re: T140V R. brake #143135 06/19/08 10:06 am
Hi Mark
Just had a HF open here. Thanks.
Mike
Re: T140V R. brake #143136 06/19/08 4:54 pm
Paul744 Offline
All I do is get a couple of foot of wire (or strong string/twine), tie it in a large loop, hook it around the spring & use it to pull the spring back over the lever. Sometimes a large screwdriver is needed to persuade the spring to slide across the lever, as described above.
Two things can go wrong. If the string/wire isn't strong enough it can snap & you'll punch yourself in the face (embarassing AND painful), or the string/wire can get trapped under the hook on the spring (just cut it & pull it out). Easy. But the setup was designed by a sadist.
hth
Re: T140V R. brake #143137 06/19/08 5:47 pm
Blapper Offline
I used a large cable tie made into a loop. It is strong enough material that you can 'pop' it out from between the spring loop and lever plate if it gets stuck.
Blapper redwine
Re: T140V R. brake #143138 06/20/08 8:26 pm
Peter Jones Offline
Or fit rear-sets and a modern cylinder in a sensible position laughing
It's an odd setup - one which I've sworn at several times.
Re: T140V R. brake #143139 06/21/08 2:26 am
Well, it's on.
Used a good sized loop of safety wire padded with a couple of rags for my sensitive fingers.
