JT441
JT441
Cadillac, MI
Filthy pup, Kevin Victor, Soupdragon, Gabby, LostMarfbles
10737 Registered Users
franko 120
DavidP 58
reverb 57
Rohan 50
923,902 mail-order LSR
Topics67,166
Posts673,141
Members10,737
68 registered members (998John), 494 guests, and 831 spiders.
True Or False #142127
05/28/08 1:14 am
05/28/08 1:14 am
Florida
camshaft1 Offline OP
Florida
I have a 68 Bonnie with Boyer Electronic ignition. When setting the idle of each carburetor individually, Is it ok to unplug one spark plug at the time without fear of ruining the Boyer black box as somebody told me????
Thanks a lot.
JJC
Re: True Or False #142128
05/28/08 2:04 am
05/28/08 2:04 am
Mark Z Offline
Mark Z  Offline
In a previous thread, it was pointed out (by Mr. Healy, I believe) that pulling a spark plug wire may cause damage to your coil, and this is with breaker point ignition as well as EI. Tension builds up in the secondary coil which is seeking a path to ground, which it may find through some weakened insulation, especially in an older coil. This will in turn cause more damage to the coil.
This practice is ok if you ground the HT lead to be disabled. You may get some suggestions on exactly how to do this.
Re: True Or False #142129
05/28/08 7:07 am
05/28/08 7:07 am
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
I agree 100% with Mark above, plus why do you need to do that anyway - I never have?
Blapper redwine
Re: True Or False #142130
05/28/08 9:19 am
05/28/08 9:19 am
dave jones Offline
dave jones  Offline
You can ground the removed ht lead by fitting another spark plug into the cap and resting it on the cylinder head, making sure it stays there.
dave
Re: True Or False #142131
05/28/08 7:51 pm
05/28/08 7:51 pm
pennsylvania, usa
dale karger Offline
dale karger  Offline
pennsylvania, usa
make a jumper wire witha sparkplug cap on one end and an alligator clip on the other so you get a positive grounding. if you do lay the sparkplug on head make sure its far from the sparkplug hole. there is still gas in the carbs and it is possible for the gas vapor escaping to be ignited by the sparking plug. that'll scare the crap out of you at the very least.
76 T140V
79 Honda CB 650
79 Yamaha 175 Enduro
68 Chevy Impala Convert
Re: True Or False #142132
05/28/08 10:30 pm
05/28/08 10:30 pm
dave jones Offline
dave jones  Offline
You don't take the plugs out of the head. You use an extra plug.
Re: True Or False #142133
05/28/08 11:02 pm
05/28/08 11:02 pm
Cincinnati, Oh
Jethro Offline
Jethro  Offline
Cincinnati, Oh
Lot of good posts to this, but I want to also mention that for ME... I haven't had to do this. I have a 71 650 engine, and am running dual VM32 Mikunis. I have a "balance" tube connecting the two carbs. I really think this tube has added a lot to low rpm idling. In fact, I searched here on the archives in reference to a balance tube. Anyway. Both carbs are set the same for jets, etc, and both slides are properly adjusted, and with the balance tube there, the bike runs damn well just as is. Do you have a problem that may be prompting the need to dial in your carbs seperately?
Re: True Or False #142134
05/29/08 6:42 am
05/29/08 6:42 am
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Anybody there?
