furymalc
furymalc
northern B.C.Canada
DaveG., stretch7, S Trotter, Psychopasta, Dave Shotz
10787 Registered Users
franko 136
NickL 72
DavidP 63
952,311 mail-order LSR
Topics67,561
Posts676,202
Members10,787
74 registered members (1958superrocket), 416 guests, and 764 spiders.
changing main cases #131721 12/30/07 1:45 am
Tri-Hook Offline OP
I have a 1966 motor that has a broken case, the normal place above the countershaft sprocket.
I would like to pull everything out of those cases and put into a set of 1970 cases.
My question: does anyone know of any problems I might run into doing ?
I would like to change everything , bearings ,ect.
Any thoughts would be appreciated.
Ronnie
Mostly Triumphs
Re: changing main cases #131722 12/30/07 1:51 pm
Dick Harris Offline
Morn'n Tri-hook, no it won't work as the '66 engine has the bushing on the timing side and the '70 has a ball bearing in that position. Why not do it the easy way and get a good welder to replace the piece above the countershaft sprocket? Dick
Re: changing main cases #131723 12/30/07 8:43 pm
dave jones Offline
We are talking unit 650 engines, are we not? The bearings are identical but the engine breathing is different. A 1970 breathes into the chaincase via the roller bearing (no oil seal) plus there is an oil level hole on the 1970 (?) as there is no separate oil supply for the primary chain. The inlet camshaft is different on a 1970 (solid) but I don't think this would make any difference if you leave off the '66 breather assembly from your 66 camshaft. The exhaust tappet oil feed is different but if you put all the 66 bits in this doesn't make any difference.
I would double check this stuff before proceeding.
If I were you, and just like Dick suggests, I would have the 66 case repaired and this is exactly what I did on my 67. SRM did it and it really was a good job for not much money.
Re: changing main cases #131724 12/30/07 8:56 pm
HawaiianTiger Offline
Keep as much of the '70 motor as possible. There are light years worth of improvements between '66 and '70 that make the '70 worth while keeping, not the least of which is the gearbox which is tons better than the '66.
Re: changing main cases #131725 12/31/07 2:35 pm
Dick Harris Offline
Dah, what made me think we were talking 500's? Guess I didn't put mind in proper gear. eek Dick
